The new CF280.UL.H cable from igus is a hybrid servo cable offered as an expansion to the chainflex line of cables for moving applications. The flexible cable can deliver motor power and feedback functions through a single cable.
Hybrid cable technology was introduced by drive manufacturers to streamline their cable connections to eliminate the encoder cable. By using bus cable technology for their encoder feedback, they’ve designed the system to work with one cable combining power and feedback functions.
igus’ new cable is specifically designed for use in the energy chain. It’s suitable for applications up to a bending radius of 10 x D across all industries, including machine tool, automotive and Intralogistics. igus has tested the CF280.UL.H inside an energy chain with a 7x bend radius for up to 8 million cycles without mechanical failure or degradation of signal. The company performs tests on all chainflex cables under real conditions at the industry’s largest test lab, which spreads out over 29,600 square feet.
The cable works reliably, even in temperatures of -13 degrees to +176 degrees Fahrenheit. A braided shield with a high covering ensures EMI protection over the life of the cable. Depending on the manufacturer’s specification, the new hybrid line has a black or orange oil-resistant polyurethane outer jacket, and is coolant-resistant and flame-retardant.
At the customer’s request, igus Readycable assembles cables in accordance to the drive manufacturers’ specifications. igus offers over 4,200 drive cables that comply to 24 manufacturer standards. All connectorized cables are electrically inspected after assembly to ensure proper function. The cable includes a 36-month service life guarantee and can be ordered in raw cable lengths or as a connectorized Readycable. The CF280.UL cable is compatible with motors and drives from over 39 manufacturers, including Siemens and Allen Bradley.
For more information, visit www.igus.com.
