You are here: Home / Industry News / Control Techniques announces new servo drive
October 15, 2018 By Danielle Collins Leave a Comment
Control Techniques, part of the Nidec group of companies, has revealed its new generation of advanced servo drive technologies.
digitax HDThe new Digitax HD servo series delivers ultimate motor control performance and flexibility from a uniquely compact package. Targeting high axis count automation systems, Digitax HD provides all of the benefits of a modular system with a common DC bus, with standalone drive flexibility. The drives’ wide power range provides 6.2 – 451.4 lb-in (0.7 – 51 Nm) with 3x peak torque (1.5 A – 16 A and 48 A peak).
The new series is focused on high overload, pulse duty applications but also provides continuous servo control, plus induction motor control, and is initially available with two functionality levels. The new Digitax HD servo solutions launched in the Americas on October 15 at Pack Expo.
Digitax M753 is designed as an optimized amplifier for high performance centralized control with EtherCAT integrated on-board and simple rotary switches for fast network address assignment. Alternatively, the flexible Digitax M751 base option allows design engineers to add up to two option modules from the existing Unidrive M range, such as PROFINET, Ethernet/IP, or an IEC61131 high performance motion controller for decentralized machine control.
Minimum size
For both single and multi-axis configurations, the Digitax HD series offers industry-leading compactness – the M753 EtherCAT variant is just 1.6 inch (40 mm) wide – that is 5 axes across the width of a piece of paper or 7 axes across if you turn it to landscape. The drive is also designed to fit within 8 inch deep (200 mm) enclosures.
Digitax HD is the most compact 400V servo drive available in the world
Its patented Ultraflow™ system allows machine builders to further reduce cabinet size by up to 50 percent through expelling heat from the drive directly outside the enclosure. This approach offers the further benefit of enabling drives to be stacked without the need for a large air channel between them.
Maximum performance
High dynamic applications will benefit immensely from Digitax HD’s 300 percent peak performance pulse-duty overload capabilities, along with its 62 μs current loop and 16 kHz switching frequency. Its flexible speed and position feedback interface supports a wide range of feedback technologies, from robust resolvers to the latest single cable digital encoder technologies.
Quick and easy installation
Digitax HD boasts a wealth of features and accessories designed to make installation and commissioning as easy as possible. Features include easy-access pluggable connectors and a dedicated multi-axis paralleling kit for rapid installation; integrated braking resistor and electronic motor name plate for faster setup; and quick commissioning using the Unidrive M Connect PC tool or an optional SD card. Machine Control Studio provides a flexible and intuitive IEC61131 environment for programming automation and motion control features.
Flexibility
The Digitax HD servo series flexibly adapts to your architecture of choice, be it centralized motion control, distributed intelligence, or any combination of the two. Support for all main industrial field-buses guarantees easy integration into any production line.
Complementary motor line-up
Working in tandem with the Digitax HD series, delivering class-leading performance with a wide torque range, up to 750 lb-in (85 Nm) with 3x peak, rated speeds from 1,000 to 6,000 rpm, several inertia levels, and a broad selection of feedback options, Unimotor hd offers the perfect fit for high dynamic applications.
Control Techniques
Filed Under: Featured, Industry News, Servo Drives Tagged With: conroltechniques, nidec
